Screenshots:
Features:-tweaked some status bar icons, like battery icon-auto brightness fixed
(*), not 100%. -added ExDialer, an MiUI style dialer. Simple, smart and fast. I like it, with multilanguage support and some themes, like in screenshoots.-changed bootanimation.-update and included: Market, SuperUser, RootExplorer, MIUI weather ...-Default
launcher: Zeam Launcher, it's simple, fast and gesture support.-dalvik2cache, sd card speed fix, build.prop changed only for better battery life.-kernel by edgar for better battery life and WiFi drivers from update-cm-7.2.0-RC0-aPT-v2 for better search and stability.
(*) I use
"Custom Auto Brightness" app, older that from Market, for me it's better, maybe the author fixes bugs in future.Read "How to use:" section on Google play for properly settings.
Download app:
http://www64.zippysh...25892/file.htmlTips:-when you first setup and entry in Playstore, touch back button, appears window with Backup and Store option, choose next and finish.-Settings/Performance/Clear memory exceptions, enable LogGraph if you don't want to kill this app (auto brightness) when you touch memory cleanup button on drop-down status bar.-some options on Settings don't work, it's normal, because I choose to use an alternative Launcher and I delete some apps from LeWa that it's not necessary.PLEASE, READ THIS FIRST BEFORE FLASH THE
ROM:+Test arhive for CRC error.+How to install:
- go to recovery' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Recovery']recovery
- wipe data/factory' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Factory_reset']factory reset
- install zip from sdcard/choose zip from sdcard
- power off
- reboot with “Master Reset”
This is the best LeWa that you can get!
Download link: http://www4.zippysha...---------------Thanks to @edgar86, @Fagulhas, Mas Hubaib, LeWa team and of course everyone that makes great android apps.
