Boas a todos.
# Venho aqui deixar a informação de uma ROM que acho interessante.
É baseada no firmware oficial da samsung.
Changelog v5.2:
- ROM Based on NEW XXLSZ Firmware
- NEW Philz Safe Kernel 4.63 for XXLSZ with CWM 6.0.2.8 Touch and exFAT Support
- NEW Modem XXLSO
- Updates Over The Air – OTA UpdateMe added on Settings
- Jelly Bean 4.1.2
- SuperSU Added
- Fully Rooted
- Fully Zipaligned
- Fully Deodexed
- Deleted some useless apps
- Added and fixed some more Build.prop tweaks for better optimization, battery life, 3G signal and network, camera, media and more…
- Added some more init.d optimizations
- Switched to MTP instead of Mass Storage, you can also use Mass Storage
- Fixed CRT OFF and fully working on XXLSZ
- Ultimate 4 Way Reboot Options for XXLSZ (just long press power button and decide what you want to do)
- SystemUI Soft Themed with semi transparent notification drawer background and cyan circle battery
- Fully working Lockscreen Shortcuts (thanks to eybee1970)
- Notification Panel into Settings with possibility to change Toggles order
- Call Recording
- Multiwindow Hack is available for unlimited apps
- Ink Effect Mod
- Dedicated app to change INK Effect Colours (thanks to mythtrandyr)
- SNote work also with productivity tools
- Airview Fix Available
- Airview in Gallery
- Added S-Voice
- Added new Android 4.2 keyboard
- Added some utilities on settings
- …and more to come!
>> LINK - ROM - : http://forum.xda-dev...d.php?t=1970626
Créditos: XDA / joosh3
by Tblank
Editado por Tblank, 15 March 2013 - 13:31.
