This is CyanogenMod 7.2 for Ideos X5 (u8800).
It is built upon the latest sources of the gingerbread branch of CM7.2.
Using 2.6.32.9 kernel with all the tweaks franciscofranco has made.
This is if you want a stable every day use rom.
All are working expect native usb tethering but you can use any usb tethering"]http://www.androidpt...']tethering[/url] app from the market.
Características:
- Overclocked kernel to 1800mhz.
- Many governors to choose from (lagfree, lazy, minmax, conservative, ondemand, smartassv2, performance).
- Noop & deadline I/O Schedulers.
- Default speed 1400Mhz , lagfree governor, deadline scheduler.
- Built from source.
- Super fast!
- Super stable!
- Bug free!
- Tweaked for better performance!
- Including X5 Settings!
- Including ksatta headset patch!
- Including screen duplicate filter by stockwell!
- Patched hosts file (adfree).
- Working native wifi & usb tethering!
- Unlocked FPS.
- CM7.2 built on 2013-02-28
Merged latest commits http://is.gd/QW4Gio - CM7.2 built on 2013-01-03
1) Revert to standard dpi and deodexed. - CM7.2 built on 2012-11-22
1) Merged all latest commits up to id I491072c0 from the gingerbread branch.
2) Changed default dpi to 182 and added modded Play Store. If you want to change back to original dpi you can do it with "Dpi Changer Utility" already included in the ROM. Don't go below 180 or above 240 dpi cause it will break things up. Default dpi is 240. Also Play Store won't auto update. You need a custom Play Store from herehttp://is.gd/SOBDEB for dpi different than 240.
3) Odexed build. Supposedly speeds up things a bit. You can read about it here http://is.gd/tpGa46 - CM7.2 built on 2012-07-21
1) All the latest merged changes on gerrit plus some cherry picks
2) Using by default a stock based kernel. Seems the same to me speed wise and a bit more battery friendly. If you would like to use the franco optimized kernel check out the downloads for and flash it through CWM. - CM7.2 built on 2012-07-11
1) Update to latest build. - CM7.2 built on 2012-06-06
1) Update to latest build. - CM7.2 built on 2012-05-09
1) Fixed some random reboots.
2) Updated ondemand governor.
3) Built upon latest CM sources. - CM7.2 built on 2012-04-20
1) Merged PaulMilbank changes to kernel. Should give more batter time! Thanks PaulMilbank (tweaked governors, set smartassv2 as default at 1024Mhz, enabled sio).
2) Further improved kernel build. Even faster now!
3) Removed NFS & CIFS.
4) Several cherry-picks from code review.
5) Change I95c987f1: Toggling the flashlight from the lock/pattern/sim unlock screens (Goto CM settings to enable this. Similar to MIUI).
6) Change I4427e3f2: [bionic] Replace strlen() with ARMv7 optimized version
7) Several other picks to improve performance.
8) Replaced Mms.apk with the one that supports 160 chars on Greek, Portuguese etc.
9) Removed 11fps from /etc/init.d/ should give bit more battery. If you need it unlocked you got to put it back and reboot.
10) Removed unnecessary build.prop lines. - CM7.2 built on 2012-04-13
http://review.cyanog....ingerbread,n,z
u8800 specific:
1) Disabled back key rejecting call.
2) Added Greek T9 dialer.
3) Patched hosts file to remove ads.
4) Edit gps.conf for fast gps accuracy on .eu users.
5) Updated adreno drivers, faster 3d performance.
6) Tweaked wifi settings to stay connected while on sleep (goes on standby).
7) Fixed native wifi tethering not getting an ip address from dhcp.
8) Couple of build.prop tweaks for 3g/net performance.
Download:
http://code.google.c.../downloads/list
Editado por djbatata, 10 March 2013 - 10:05.
