#include /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. * * Submitting bug reports on nightly builds is the leading * cause of male impotence. */
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
http://teamhacksung....ly:Known_issues
http://teamhacksung....Asked_Questions
First time installing CyanogenMod 9 to your Galaxy S III, or coming from another ROM:
- READ FAQs: http://teamhacksung....Asked_Questions
- Make sure you're running a proper working ClockworkMod' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Cwm']ClockworkMod- recovery' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Recovery']recovery (CF-root' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Root']root for example). If you're not sure, you can follow this guide: http://wiki.cyanogen...ll_Update_Guide
- Copy GApps and CM9 ZIPs to your internal SDCard
- Boot into recovery' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Recovery']recovery
- Flash CM9 zip
- Flash GApps zip
- DO A DATA WIPE / factory' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Factory_reset']factory reset (otherwise your calendar sync will not work)
- Reboot
- Don't restore Apps using Titanium Backup!
- If you Wi-Fi doesn't work, remove /data/.cid.info with a root' class='bbc_url' title='Link Externo' rel='nofollow external'>http://www.androidpt.info/index.php?title=Root']root-enabled file explorer.
Upgrading from earlier version of CyanogenMod 9:
- Copy CM9 ZIP to your internal SDCard
- Flash CM9 zip
- Reboot
STOP!!!
Did you read THIS POST fully, the FAQs and KNOWN ISSUES?
Nightly builds:
http://get.cm/?device=i9300
Google Apps:
Get the latest Version from Rom-Manager. We recommend to use 20120317.
Newer, unsupported versions can be found at http://goo.im/gapps
http://changelog.bbq...#i9300/cm9/next
http://www.cyanogenm.../about/features
Don't expect any support if you:
- are not running stock cm-kernel
- have installed any mods
- have modified system files
atinm, codeworkx, xplodwild, coolya, guiper, nebkat, Unhelpful, teamhacksung, the cyanogenmod-team.
http://github.com/cyanogenmod
http://github.com/te...e_samsung_i9300
http://github.com/te...amsung_smdk4412
If you want to donate a few bucks for the work we're doing, goto teamhacksung website and hit the big donate button.
Thanks to all donators!
fonte: http://forum.xda-dev...d.php?t=1714354
Editado por lemmon, 18 June 2012 - 18:34.
