[T]he [M]ost [C]lean
CyanogenMod 7.2.0
04.01.2013
Características:
- based on CyanogenMod 7.2.0 RC2
- Completely clean
- Bug free!
- CPU has stable frequencies up to 1.8 Ghz with modded kernel
- Incoming / outgoing sounds are clean - high
- Fully multilanguage
- FPS locked to 45 for prevent the fluctuation of the screen and improve battery performance. If you are prompted,you can unlock it.
- Media Profiles (video-camera settings) taken from Elite X1
- Experience lifelike colors on the screen with Bravia Engine.
- Wi-Fi drivers have been updated. Now, more than 15 Mbit download speed, even in the WPA
- Accelerometer works stable.
- Compass is working stable. (after calibrate)
- Light sensor reacts quickly.
- Additional theme support (by CM7)
- Stable even at 600 Mhz.
- USB Tether works. Use Barnacle Tether for Wifi Tether.
- Customized settings for the RAM (Thanks MosTERRA)
- Database IO performance is better with modded sqlite.
- If you select auto 3G/2G mobile settings, the device gives higly priority to 3G.
- ZRAM turned on by default.
- You can play Gameloft games without any need for correction of build.prop
- You can see internal and external storages at the same time in the PC and phone.
Changelog:
29012013 ----> 18022013
- WiFi driver changed to genokolar's driver. It may slower but more stable than offical wlan driver
04012013 ----> 29012013
- "Phone sometimes going to bootloop on bootanimation" is really fixed now
- WiFi drivers are updated from offical GB by Huawei.
- Audio drivers are updated from lastest ICS drivers in kernel
- Atmel Touch Screen driver updated by me (increased feedback,fixed the lag). Now, as good as in 2.6.32.9
- Other updates
01012013 ----> 04012013
- Added SmartAssV2 governor
- Added & enabled bfq i/o schulder by default
- Keypad led brightness is reduced
- Added haptic feedback for soft keys support. You can enable this in X5 Settings
- some fixes for bluetooth problems
- Disabled second mic and voice quality is improved
- Added X5 Settings
- changed some voltages for system stability and battery life. also You can change voltage volues with Antutu CPU Master
- Lag on Atmel TS is fixed but I'm not sure,please give me a feedback about this
- Font changed to "Ubuntu" font
16122012 ----> 01012013
- Sensors are updated. All of sensors are working
- Compass fixed
- Added some tweaks for battery & stability
- This update will wipe dalvik-cache so the first boot after update may take longer than other
09122012 ----> 16122012
- "Phone sometimes going to bootloop on bootanimation" is fixed
- Disabled Beats Audio,Added DSPManager
- VSYNC turned on,battery will not draining
04082012 ----> 09122012
- Builded from lastest CyanogenMod source so base is fully changed
- Kernel Changed (with a lot of updates)
- Some libraries taken from LeWaOS
- Fixed a lot of updates
- etc
12072012 ----> 04082012
- Beats Audio added,DSP Manager deleted
- Bravia Engine updated
- Themes comes by default and ICS Theme is enabled by default.
- Revert to genokolar's CM7 and I fixed a lot of bug,so it runs more stable and faster.
- My preference, use auto task terminator for more RAM.
- FPS unlocked (up to 55 fps)
- ZRAM turned off
- Added Google Maps and Google Talk
First release ----> 12072012
- CyanogenMod base was changed to RC0
- Written host file blocking ads
- Nemus Launcher updated, will be less teasing.
- Written scripts against overheating.
- Shortened time connecting to Wifi
- Many tweaks for games.
Download:
http://code.google.c...13.zip&can=2&q=
Editado por djbatata, 10 March 2013 - 10:10.
