HOWTO install
- If you installed the CWM reocvery by @Dexter_nlb, remember to press install recovery again, so the changes take effect.
- Get your o4x root'd,
- Download the APK file and install it
- after installation reboot mobile once (if you do not, the app might fail installing recovery)
- start the LG 4X Recovery app
- press - Install recovery - grant superuser access when prompted
--- Three option lines in the app: 1st Install Recovery, 2nd Reboot Into Recovery, 3rd Normal Reboot
- wait for success OK, if it fails, something is wrong or SU is not properly installed or denied su access. you should set permissions to granted for this app
- after successfull installation, you can press boot recovery and boot into the twrp recovery and make your backups or install custom roms
Fonte:
http://forum.xda-dev...d.php?t=1826378
Editado por rmdgms, 30 January 2013 - 15:39.
