Finally X Power is here, the ROM is all about battery and smoothness, not hottest mods, beta releases etc.
This ROM is stock like, no theaming. just small mods. I'll always try to get out the best battery life with phone running smooth as silk.
I'll will not be first to release new roms as battery optimize & smoothness takes a bit of time.
PS. PICTURE IS THEMED. ROM HAS STOCK LOOK WITH STOCK ICONS IN STATUSBAR
HOW TO install:
- Install CWM(or clockwork mod) for custom recovery
- Download ROM and place on root of SD card.
- Boot into recovery and flash the zip
- ALWAYS BACK UP YOUR CURRENT ROM
- Reboot and Enjoy X-Power
DOWNLOAD SECTION:
DOWNLOAD X_Power_5.0.0 HERE!!!- DONT FORGET TO REBOOT AFTER FIRST SETUP....
UPDATE_5.X.X_TO_X_Power_5.1.1.zip INSTALL ONLY AFTER INITIAL SETUP OF ORIGINAL ROM (5.0.0)
Trial jkay deluxe settings app here... (MUST DISCONNECT INTERNET to get the trial 3times)
CHANGELOG:
---> 5.1.1 battery fix:
updated kernel script.
And as a reminder, don't forget the ink effect on lockscreen, accessible in setting lockscreen, after installing and have run jkay deluxe settings.
---> 5.0.0 with new POWER save beta:
MODEM=XXCMB2 - best ever
KERNEL=Perseus 33.3 with script optimization by me
Base its BMB5 redesigned by me deodexed by r_i_x
made some volumes levels higher for higher volume in headphones etc.
Updated all mods to new base
Included jkay 92.9 modded by me for battery, no need to upgrade until new functions emerge, as newer jkay is for newer builds on regular s III, you can always flash newer, only drawback would be battery life. I'll let you try
New scripts for performance and battery in kernel, let me know how it's working for you compared to old 4.0.0 with the same apps and usage...
made some apps adjustments on whats included.
GOT GREAT PERFORMENCE AND BATTERY ON THIS SO FAR....
---> 4.0.0 New version:
MODEM=XXBMA2 - best ever
KERNEL=BMB4
Base its BMB4 redesigned by me
Updated all mods
Updated all apps
Included jkay 92.6 modded by me for battery, no need to upgrade until new functions emerge, as newer jkay is for newer builds on regular s III, you can always flash newer, only drawback would be battery life. I'll let you try
Newer scripts for performance and battery, let me know how it's working for you compared to old 3.0.0 with the same apps and usage...
SaME MODS as in earlier roms
---> 2.5.0, altered and reloaded as 3.0.0:
BASE OFFICIAL JB XXBMA6 and XXBMA4
MODEM=BLL5
KERNEL=BMA6
New base is a mix, and much better performance way...
Snappier overall ROM
better battery life
new improved tweaks for both battery and speed
new JKAY 14.91.2, THE ALL APPS IN MULTIWINDOWS wont work, iv'e ADDED the MULTI WINDOW APP FOR THAT.
Small themed status bar to my old AOSP blue icons, and also quick settings icons.
Will release theme as standalone zip
all mods and tweaks from 2.0.0 is also in this rom
---> 2.0.0:
BASE OFFICIAL JB XXBMA6 (PURE)
Camera with HQ video and more
even better battery life
by optimizing the codes for battery life, phone will also be snappier
many many optimization of jar files smali code & more
and one hell of a lot of small mods and tweaks
callrecording
JKAY mod 14.9, TO USE IT YOU MUST BUY DELUXE SETTINGS IN PLAY STORE (trial is coming in the future JKAY told me so) otherwise everything is stock except lockscreen.
Media scanner fix
Multi window fix with multi windows app to put apps in multi window bar
themed multi window bar
PERSUS kernel
STWEAKS
Xperia swype keyboard
Rolle tube (youtube app with download)
updated stock apps
Mirror
MMS more contacts sending
Fast dormacy setting app (thx jkay)
adobe flashplayer
android docs (drive)
download all files
adobe air
and maybe others i forgot
USE STWEAKS TO MAKE THE MOST OF YOUR BATTERY, BY UNDERVOLTING, AND MORE.
OR MAKE YOUR DEVICE FASTER WITH IT, RAISE VOLUME AND MORE
PS. the rom takes about 3days to settle down and to give the best battery life there is, -A small step for mankind, one giant leap for mankind
Esta ROM é excelente para quem quer poupar o máximo de bateria possível, não quer muitos mods e muitas mudanças. Deixo aqui o link oficial da ROM para qualquer dúvida mais específica que tenham: http://forum.xda-dev...d.php?t=2118686
Editado por JMCMagano, 16 March 2013 - 19:40.
